16 years agoMinimal Setup of NIOS + EPCS not Working
Hi, I am trying to insert the EPCS serial Flash Loader to a NIOS system without any success. I would like to know if someone has an idea what is missing. .sopc file is attached, and it is an...
16 years ago --- Quote Start --- Serial is always useful. Failing that a single LED! These days it is possible to get TTL <=> USB serial adapters that plug onto a 4 pin 0.1" (and probably other) header. They significantly reduce the board space (and cost) of adding a serial debug port. --- Quote End --- Hi dsl, I change allready the jtag uart for a real uart. and it is running as before. However the EPCS problem is still there,, Any ideas? P.S. When I press the reset program is not starting again, I asume it is because it is jumping to the reset address pointing to the flash. how can I make it jump to the starting address without recompiling the sopc?
