16 years agoMinimal Setup of NIOS + EPCS not Working
Hi, I am trying to insert the EPCS serial Flash Loader to a NIOS system without any success. I would like to know if someone has an idea what is missing. .sopc file is attached, and it is an...
16 years agoThankyou dsl,
it is a good hardware solution for next time. At the moment I allready got the serial connector attached to some free GPIO I had free on the board. The Version Without JTAG serial but instead a normal UART is at least smaller, < 1K, However I still have the same problem with EPCS. Flash Programer can not access it. I am wondering what is the last lines on the log. EPCS signature is 0x00 EPCS identifier is 0x000000 "No EPCS layout data - looking for section [EPCS-000000]" Unable to use EPCS device Leaving target processor paused Error code: 8 for command $SOPC_KIT_NIOS2/bin/.......... in SOPC the flash is in 0x00041800, Why is it trying to find, so that it is going all the way to 0x00041B00? It is saying somethng about reserved fields non-zero... any ideas? Thanyouo again.
