16 years agoMinimal Setup of NIOS + EPCS not Working
Hi, I am trying to insert the EPCS serial Flash Loader to a NIOS system without any success. I would like to know if someone has an idea what is missing. .sopc file is attached, and it is an...
16 years agoAt the moment the jtag debugger is the only way of looking if nios is running, by reading out the stdio.
I might try it now without jtag debugger, I will try to use some other means, like maybe a normal serial rs232. This board is ment to be debugged via TCP, but if this simple project is not running, I am far from being able to debug via tcp. (this was the original project, but at this moment I am trying to do keep it simple untill it works and then I need to put the epcs on the original project with tmac etc.) Thankyou
