15 years agoMicroC/OS-II tutorial problem
Hi, I'm new to nios II and microC/OS-II, recently i had work with a project which need to implement the microC/OS-II with nios II embedded evaluation kit. So i tend to start my project with the tutorial named "using microc/os-ii rtos with the nios ii processor tutorial (pdf)". Google it microc/os-ii rtos with the nios ii processor for the pdf file.
I had follow exactly what the tutorial show, but once i start create the bsp and application (step 11 pdf file). It miss out one folder named ucosii_tutorial. i had try several times but the problem still there. I hope you guys can show me whats the problem. Thanks.2 Replies
Hi
That tutorial has worked in my board, I dont understand well what is the problem with your project. Please, post more info to help you. - Altera_Forum
Hi
I know whats the problem, as i still using the old version of the Quartus II software so was not able to the build it. Anyway, thanks.
