15 years agoMicroC-OSII mutexs
does anyone know if you can define multiple mutexs in microC OS 2?
I have more than one shared resource that I would like to have different semaphores for. But I would like to use mutex semaphores. Based on the microC OS 2 book, it seems like you can only make 1 mutex :confused: am i missing something?3 Replies
maybe he has a mistake in his example in chapter 8.1 of his book?
He has a line of code that says OSMutexCreate(9,&err); I think maybe this should read ResourceMutex = OSMutexCreate(9,&err); ??? I guess the question is do you need to create an OS_EVENT* type and set it eqaual to OSMutexCreate() ? It must just be a mistake in the documentation. Can someone confirm? - Altera_Forum
My uC/OS-2 manual reads
DispMutex = OSMutexCreate(20, &err); Based on this i see no reason why there should be not more then 1 Mutex in a System. What you need to do is reserve enough space for the event control blocks in the system lib settings. karsten - Altera_Forum
thank you, yes I believe you are correct.
