14 years agoMicro C stops and does not resume
Hello, I have a problem using Micro C in Nios EDS. I do not have a wide experience working with Nios EDS and I am sorry if my problem is basic but I have not been able to find the solution. ...
14 years agoHello Cris72,
I solved the problem, I did two modifications and now it is working well! Let me explain the modifications.. Firstly, I assigned the global reset to the CPU reset of the board instead of to Vcc. Secondly, I downloaded the .pof in Quartus II using the active serial programming instead of the .sof with JTAG mode. Thus, the hardware design is downloaded permanently. I am very grateful to you for your help;) Many thanks, Best regards
