14 years agoMicro C stops and does not resume
Hello, I have a problem using Micro C in Nios EDS. I do not have a wide experience working with Nios EDS and I am sorry if my problem is basic but I have not been able to find the solution. ...
14 years agoCris72, many thanks for your help :)
I have new information... I debugged again and I created a variable called "prova" with the value of OSTCBList before the infinte loop. I attach a pdf with the values of this variable. As can be seen, OSTCBPrio is never the same as OS_IDLE_PRIO (or OS_TASK_IDLE_PRIO depending on the version of Quartus II) and so it is the reason for which there is an infinite loop. The reason is clear, but I dont understand why. I hope this information is useful to solve the problem. Any help is welcome ;) Many thanks!
