20 years agoMessage boxes in eCos
Hi all, cyg_mbox_peek (), is always returning the count 1 less than the actual number of messages in the message box. When the message box is empty, then count is returned as 0. Why this is so?...
20 years agoHi,
Thanks Sepp for your suggestion. The program is giving correct results now, using cyg_mbox_tryget () instead of cyg_mbox_get (). But still I have one doubt. The reason that you had specified for cyg_mbox_get () is okay, but then using that concept cyg_mbox_peek () would always had returned the count as 0? With regards, Sanjay Sanjay, I am not using the function cyg_mbox_peek () so I have no idea. What I am doing is something like this and it works fine: sending thread: while(1) { ... // when a message should be sent: if(!cyg_mbox_timed_put(mbox_hdl,(void *)psMsg1,1000)) { psMsg1 = NULL; // Do something to resend the message } else { // wait for acknowledge ret = cyg_flag_wait(&FlgAckMsg,FLG_MBOX_ACK,CYG_FLAG_WAITMODE_AND | CYG_FLAG_WAITMODE_CLR); } ... } receiving thread: while(1) { ... // allways have a look if there is a new message pMsg= cyg_mbox_tryget(mbox_hdl); if(pMsg2 != NULL) { save message: // Saving the message data into a local struct acknowledge: cyg_flag_setbits(&FlgAckMsg,FLG_MBOX_ACK); work with received data: // Decoding the received message and do some action with it } ... } Regards, Sepp
