14 years agoMay I use tcp and udp simultaneously within a iniche stack
May I use tcp and udp simultaneously within a iniche stack?
how to implement? //create two task for each like the simple socket server? thanks a lot for your help!3 Replies
I have implement two tcp task,and it works well.
next: implement a tcp task and a udp task. - Altera_Forum
Sure, you can.
What's the problem? If you already implemented two tcp tasks, you only need to change one socket from SOCK_STREAM to SOCK_DGRAM - Altera_Forum
yes. I change the tcp socket to sock_DGRAM.
and I have implemented 1 tcp task and 1 udp task. and they worked well.
