max10 remote system update nios with uart
hii frank thanks for your reply i saw in example design that is published in altera store called max10_rsu that they used both on chip flash and ram memory for the nios 2
i attached the picture of the nios 2 configurations and you can see that the picture that the nios 2 reset vector memory is configured to be generic quad spi controller and the exception vector memory is on chip memory
and if i understand you correctly i only need qspi as a memory for nios 2 ? so what do i need to do ? i built my system according to the altera example
1-do i need to set the exception vector also to generic quad spi controller also? and remove the on chip memory from my system
i be glad for help ?
Hello
Can you check your design settings in Quartus with the example design settings, the link below provides the file for the example that you are trying to follow
- aiedb1 year ago
hii when i compile this project i get errors due to licince issues how can i solve it ?
- Sparrow_Altera1 year ago
Hello
Let me check and get back to you. Thanks.
Hello
Nios II is EOL, Altera stop selling Nios II/f license.
New users need to migrate to Nios V and apply the Nios V license.
Regarding the example design, couple of points below that can help you.
To simplify the design, it can be divided into three function blocks:
- RSU block (Dual Configuration IP to handle RSU)
- UART block (Communication thru UART)
- Booting block (Nios to boot from QSPI)
UART block (Communication thru UART, such as printf & scanf)
Booting block (Nios booting from QSPI)
Below User Guides will help you to understand more about these function blocks.
- MAX® 10 FPGA Configuration User Guide (How does Dual Configuration IP handle Max 10 RSU?)
- MAX® 10 User Flash Memory User Guide (Dual Configuration IP switches the target CFM only, you will need On-Chip Flash IP to change the FPGA Image in CFM)
- UART Core (Altera HAL driver to send/receive UART data in Software Programming Model subchapter)
- Nios® II Processor Booting from QSPI Flash (QSPI Controller + OCRAM is a must to boot Nios II from QSPI)
- Nios® V Processor Booting from General Purpose QSPI Flash (QSPI Controller + OCRAM is a must to boot Nios V from QSPI)
And finally connecting the 3 logic blocks to get the whole design,
- aiedb1 year ago
hii thanks a lot for reply that helped me alot
now i understand what is the problem
