8 years agoMaking Simple Sockets Server run Standalone
Is there a way to have this example program which uses Telnet on port 30, for a Max10 FPGA, to run without the aid of the NIOS II Eclipse software? In other words, can I set it up to just have the F...
8 years agoYou will need logic to decode the IP and TCP layers, as well as a Mac and something to talk to the phy. These can be done with a core but you need something to decode the TCP after the IP later is stripped off.
