8 years agoMaking Simple Sockets Server run Standalone
Is there a way to have this example program which uses Telnet on port 30, for a Max10 FPGA, to run without the aid of the NIOS II Eclipse software? In other words, can I set it up to just have the F...
8 years ago --- Quote Start --- Even if you do, what are you going to talk to? You'd need something to decode the incoming commands and give some sort of response. A nios will be the easiest option. --- Quote End --- NIOS would run internally on the MAX10 FPGA. I'm just saying I'd only want to connect Ethernet, no uart/JTAG cable. And it would be self-bootable. Is this possible?
