8 years agomake error
Hi all , While trying to compile Altera UP example i.e both_buffers , Nios ide generated this error : Description Resource Path Location Type make: *** [buffers.elf] Error 1 buffers C...
8 years agoHi,
Has mentioned above, I have also set on-chip ram size to "262144" bytes & used both_buffer file and created a simple project.I was able to generate the .elf and memory initialization file. 1.Recheck whether a correct sopcinfo file is loaded. 2.Kindly delete the incremental_db, db & software folder created in the project directory. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
