21 years agolwip MicroC/OS-II throughput
Does anyone know if the throughput rates on pate 1-31 of the "Using Lightweight IO with the Nios II Processor tutorial" document was for 100Mbps ethernet? The transmit rate of 5.16 Mbps seems r...
21 years agoI made the following changes which compiled and tested ok, but haven't done any comparative performance measurements yet.
1.) Added the following code to: \altera\kits\nios2\components\altera_lwip\UCOSII\inc\lwipopts.h /* * Enable LightWeight Protection. * Refer \altera\kits\nios2\components\altera_lwip\UCOSII\src\downloads\lwip-1.1.0\src\include\lwip\sys.h * for changes to the SYS_ARCH_DECL_PROTECT(), SYS_ARCH_PROTECT() and * SYS_ARCH_UNPROTECT() macros. */# define SYS_LIGHTWEIGHT_PROT 1 2.) Made the following changes in: \altera\kits\nios2\components\altera_lwip\UCOSII\src\downloads\lwip-1.1.0\src\include\lwip\sys.h /** SYS_ARCH_DECL_PROTECT * declare a protection variable. This macro will default to defining a variable of * type sys_prot_t. If a particular port needs a different implementation, then * this macro may be defined in sys_arch.h. */ //#define SYS_ARCH_DECL_PROTECT(lev) sys_prot_t lev# define SYS_ARCH_DECL_PROTECT(lev) alt_irq_context lev /** SYS_ARCH_PROTECT * Perform a "fast" protect. This could be implemented by * disabling interrupts for an embedded system or by using a semaphore or * mutex. The implementation should allow calling SYS_ARCH_PROTECT when * already protected. The old protection level is returned in the variable * "lev". This macro will default to calling the sys_arch_protect() function * which should be implemented in sys_arch.c. If a particular port needs a * different implementation, then this macro may be defined in sys_arch.h */ //#define SYS_ARCH_PROTECT(lev) lev = sys_arch_protect()# define SYS_ARCH_PROTECT(lev) lev = alt_irq_disable_all() /** SYS_ARCH_UNPROTECT * Perform a "fast" set of the protection level to "lev". This could be * implemented by setting the interrupt level to "lev" within the MACRO or by * using a semaphore or mutex. This macro will default to calling the * sys_arch_unprotect() function which should be implemented in * sys_arch.c. If a particular port needs a different implementation, then * this macro may be defined in sys_arch.h */ //#define SYS_ARCH_UNPROTECT(lev) sys_arch_unprotect(lev)# define SYS_ARCH_UNPROTECT(lev) alt_irq_enable_all(lev) //sys_prot_t sys_arch_protect(void); //void sys_arch_unprotect(sys_prot_t pval); 3.) Added the following include to: \altera\kits\nios2\components\altera_lwip\UCOSII\src\downloads\lwip-1.1.0\src\core\pbuf.c \altera\kits\nios2\components\altera_lwip\UCOSII\src\downloads\lwip-1.1.0\src\core\memp.c # include "sys/alt_irq.h" Not sure about any of the other tuning options, haven't got that far yet. ciao
