21 years agolwip MicroC/OS-II throughput
Does anyone know if the throughput rates on pate 1-31 of the "Using Lightweight IO with the Nios II Processor tutorial" document was for 100Mbps ethernet? The transmit rate of 5.16 Mbps seems r...
21 years agohi rugbybloke
i've used the Stratix 1S10 development with the "full featured" example with some modifications: -Nios II (f) 100 MHz,Instruction cache:16Kbytes,Data cache:4Kbytes (also the SDRAM has a 100 MHz clock, with delay...) -System_clk_timer->Initial period:10 ms (is the tick used by UCOSii) -debug module level 1 -no onchip ram Moreover, in the IDE, u have to set "optimization level: -O3" in your program and in the associated library. My test program uses UNIX socket to only trasmit or receive continuosly (test tx or test rx) UDP packet of variable length: in the tx test i send an incremental counter to a software running in a PC connected through a LAN cross cable with the board, in the rx test i check this counter. bye
