alemannia
7 years agoLow coremark benchmark score on Cyclone V (ARM Cortex A9)
Hi, I'm using a low speed grade (-C8) Cyclone V with HPS (single core ARM Cortex A9). IC-5C SE B A4 U 19 C 8 S-TMP The code development is done on bare-metal (freeRTOS) with MPL as bootloader. All...
FawazJ_Altera
7 years agoHello,
It seems this is a compiler optimization issue.
So you mentioned that when using the gcc or armcc, the performance is as expected, right? please correct me if I am wrong.
May I know which compiler did you use?
