15 years agoLinux/MMU + TSE on 3C120
Hi, I have got a 3C120 dev board from Altera and cannot make the TSE working. I'm using the latest sources of Linux (branch nios2) and have a very strange phenomena: if I patch the 'al...
15 years agoThanks for your answer.
I haven't got a crossed cable right here so can't do a direct connection, but I will find one. My FAE told me that the constraints used for the design assert that the clock is centered around the data, which may need a special configuration of the PHY. Because I would avoid to modify the Linux kernel, I may have to change something in my clocks, but I don't know enough on hardware for that. My dev workstation is an old RHEL5 and I have only tcpdump. I will try also to find Wireshark that should give me more info on the errors...
