17 years agolinux:cant use make vendor_hwselect like uclinux
hi after make menuconfig i want to map my *.ptf file,i think it will like uclinux ,then i input make vendor_hwselect SYSPTF/... but it report erros as below: [root@localhost uClinux-di...
16 years agoThanks for you replies.
I am not able to configure Nois2 for custom fpga (highlighted in red). I don't get that option when I run 'make menuconfig' What am I missing here? How do I make the kernel to look for custom_fpga.h? cd uClinux-dist make menuconfig # select Altera,nios2. kernel config your FPGA. NiosII Configuration --->NiosII FPGA configuration --->(X) CUSTOM_FPGA makeThanks for you patience, regards,priya
