15 years ago
Linux freeze JTAG problem
Hi all,
I've got a problem on my board. Whereas I selected in Device Drivers-> Character devices -> Serial drivers :
[*] Bypass output when no connection
My uClinux freeze after 5 minutes of perfectly running.
When I plug the JTAG and do a " nios2-terminal " on my computer, all the " dmesg " is printed on the console and the uClinux comes backs to life.
It looks like a fifo full and as soon as I empty the the fifo everything is fine.
Does anybody got an idea ?
Thanks in advance.
    I didn't found what to do ...
    Does anybody can help me. Nobody got this problem ?
    JTAG serial ports having this type of problems. xilinx does the same without linux also. the option "Bypass output when no connection" should actually solve this problem, I do not know.
    Thank you neolux.
    Does a Guru have solution for my problem ?
    I just ran into this problem too. It works most of the time, when only the normal boot messages get printed to the console. But if something happens that prints out a lot of messages, such as the OOM killer, Linux hangs until I connect with a nios2-terminal. I'm looking through the altera_jtaguart source to try to track down the problem, but any help would be appreciated.
    Please tell me what solution did you found to solve this problem !
    Hello guys,
    i had this problem either but without using uCLinux.
    The same problem appears when using the µC/OS-II operating system.
    There the problem lies within the altera hal.
    I could fix it, using the following defines symbols (for the preprocessor):
    ALTERA_AVALON_JTAG_UART_BUF_LEN=8192
    This increases the buffer.
    And within the source-code i used this ioctl to setup the non-blocking mode:
    fcntl(STDOUT_FILENO, F_SETFL, O_NONBLOCK);
    fcntl(STDERR_FILENO, F_SETFL, O_NONBLOCK);
    I don't know if this sollution can be ported to uCLinux?!
    I was running into this problem with JTAG, and Linux wouldn't boot from flash without a console, so I am now using a netconsole to work around the problems.
    menuconfig > Device Driver > Network Device Support > Network console logging support
    see linux-2.6/Documentation/networking/netconsole.txt
