14 years agoLinux doesn't boot --> Please Help
Hello all, i still have problems to boot uCLinux on my FPGA-System. I carefully read every article within the Linux categorie on the Altera wicki. I'am the nios2-branch and checked out the lat...
14 years agoYes, the address looks correct. 0xC0000000 is added to map the address into the kernel memory region.
You can find the kernel config in uClinux-dist/linux-2.6.x/.config, but that should be ok then, if you followed the instructions from the wiki.
