14 years agoLinux doesn't boot --> Please Help
Hello all, i still have problems to boot uCLinux on my FPGA-System. I carefully read every article within the Linux categorie on the Altera wicki. I'am the nios2-branch and checked out the lat...
14 years agoYes is select the device driver and console support for the JTAG UART, but i didn't set the SERIAL_ALTERA_JTAGUART_CONSOLE_BYPASS.
I also changed the bootargs within the dts file to: bootargs = "debug console=ttyJ0,115200" I will test console-bypass option. Where can i find the kernel config? Is it a problem using kernel v3.1?? (in the first window, comming up when entering make xconfig there is an entry "Kernel is linux-2.6.x") Thanks
