14 years agoLinux doesn't boot --> Please Help
Hello all, i still have problems to boot uCLinux on my FPGA-System. I carefully read every article within the Linux categorie on the Altera wicki. I'am the nios2-branch and checked out the lat...
14 years agoDid you select the proper serial driver (SERIAL_ALTERA_JTAGUART) and console support (SERIAL_ALTERA_JTAGUART_CONSOLE) in kernel configuration (you posted your uClinux-dist config instead of your kernel config)? You might also need to set SERIAL_ALTERA_JTAGUART_CONSOLE_BYPASS.
