15 years agoLinking error in Nios II .elf file
Hi, The following errors occur when i try to build a simple "hello world" application. c:/altera/11.0/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/b...
14 years agoHi All
I've the same issue.... :-( But I'm not able to create a small C library, could you please explain to me where can i find this option? Is it also possible to load all into DDR ram? I'm at 87.9 mph but I can't go haed...
