15 years agoLinking error in Nios II .elf file
Hi, The following errors occur when i try to build a simple "hello world" application. c:/altera/11.0/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/b...
15 years agoThe 'hello world' example pulls in a lot of libc - IIRC it is about 70k code - probably larger than your internal memory.
You need to select the small libc.
