14 years agolcd16207 not working
I am trying to print anything on lcd display on my de2 board.
uClinux/Nios II
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032
Kernel command line:
NR_IRQS:32
PID hash table entries: 32 (order: 5, 128 bytes)
Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 4644k/3267k RAM, 0k/0k ROM (1669k kernel code, 1598k data)
Calibrating delay loop... 44.74 BogoMIPS (lpj=223744)
Mount-cache hash table entries: 512
net_namespace: 264 bytes
NET: Registered protocol family 16
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
ttyJ0 at MMIO 0x6810f0 (irq = 1) is a Altera JTAG UART
console enabled
ttyS0 at MMIO 0x681000 (irq = 2) is a Altera UART
dm9000 Ethernet Driver, V1.31
dm9000 dm9000.0: eth%d: Invalid ethernet MAC address. Please set using ifconfig
eth0 (dm9000): not using net_device_ops yet
eth0: dm9000e at 806810f8,806810fc IRQ 6 MAC: 00:00:00:00:00:00 (chip)
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Freeing unused kernel memory: 1368k freed (0x9da000 - 0xb2f000)
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc -o noexec,nosuid,nodev
Command: mount -t sysfs sysfs /sys -o noexec,nosuid,nodev
Command: mount -t devpts devpts /dev/pts -o noexec,nosuid
Command: mount -t usbfs none /proc/bus/usb
mount: mounting none on /proc/bus/usb failed: No such file or directory
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
Execution Finished, Exiting
Sash command shell (version 1.1.1)
/> cd bin
/bin> ls
arp boa busybox cat chmod
cp dd dhcpcd dmesg echo
ethtool ftp ftpd hostname hush
ifconfig inetd init inputattach kill
lcd lcd16207 lcd16207.c lcd16207.gdb lcd16207.o
lcd_16207.h lcdtime lcdtime.c lcdtime.gdb lcdtime.o
leds leds.c leds.gdb login ls
make_examples mount msh netstat netstat-nat
ping ps readf readf.c readf.gdb
readf.o rm route routed sh
telnetd writef writef.c writef.gdb writef.o
/bin> lcd16207 "fdsfs"
Can't open device file: /dev/lcd16207
/bin> I try to run example lcd16207 program from altera wiki and it doesnt work. Ive changed defined addresess to # define ADR_LCD_COMMAND na_lcd_16207_0 + 0x80000000 # define ADR_LCD_READY (na_lcd_16207_0 + 0x80000000 +4) # define ADR_LCD_DATA (na_lcd_16207_0 + 0x80000000 + 8) # define ADR_LCD_READ (na_lcd_16207_0 + 0x80000000 + 12) I have no idea what to do? Which drivers should I use? Ive tried to follow the steps from "Device drivers and Test application for a SOPC solution with Nios II softcore processor and μClinux" but I cannot find de2_drivers which were use there since the files are no longer available on the serwer. Please help me cause I am really confused now how it should work :)2 Replies
what is very important? I didnt find any solution
Did you load the module before you want to use the application?
