10 years ago'Launching a Hello World Nios II Hardware configuration' has encountered a problem.
Hi all, After successful building of sample hello world project, self has chosen 'Run As' and 'Nios II Hardware' options to check the execution as per the steps written in instruction manual for b...
10 years agoTwo things: 1) You need to run your build in the Nios II command shell. 2) There may be a problem if you have spaces or non ASCII characters in your file path.
- MLowe37 years ago
I am having trouble running from the Command Line or the GUI. When I try from the Command Line, my Makefile doesn't create an executable file. When I try to run from the GUI, it gives error saying 'downloading ELF process failed' and 'target processor not responding'. I am running v18.1 which may be my problem since I am trying to use older demos and other project files to build this. Can you advise best way to use ADC to display results on 7seg and store them in on-chip memory.
