10 years ago'Launching a Hello World Nios II Hardware configuration' has encountered a problem.
Hi all, After successful building of sample hello world project, self has chosen 'Run As' and 'Nios II Hardware' options to check the execution as per the steps written in instruction manual for b...
10 years agowho can help me about the problem below ?
**** Build of configuration Default for project mynios_ch395 **** make all 系统找不到指定的路径。 系统找不到指定的路径。 Info: Building ../mynios_ch395_bsp/ make --no-print-directory -C ../mynios_ch395_bsp/ cygpath: can't convert empty path process_begin: CreateProcess(NULL, pwd, ...) failed. make[1]: *** No rule to make target `/system.h', needed by `all'. Stop. make: *** [../mynios_ch395_bsp/-recurs-make-lib] Error 2 **** Build Finished ****
