10 years ago'Launching a Hello World Nios II Hardware configuration' has encountered a problem.
Hi all, After successful building of sample hello world project, self has chosen 'Run As' and 'Nios II Hardware' options to check the execution as per the steps written in instruction manual for b...
10 years agoHello Babloo,
Are you sure you added the .QIP file, generated by qsys to your project ? You can do this under assingment / settings / files, there shoud be a .QIP file added to the project. As far as I know, this file is used as a kind of reference so Quartus can find the file generated by Qsys. If you do forget this step, the Qsys device will not compile ? If you are not sure that qsys updated the .v files in the automatically generated code, delete it, generate again from qsys, they should re-appear. Best regards, Jogi
