8 years agoKernel Panic programing fpga from Linux
Hello Community,
I receive the following error when I want to program the fpga from Linux:
fpga_manager fpga0: writing fpga.rbf to Altera SOCFPGA FPGA Manager
Unable to handle kernel NULL pointer dereference at virtual address 00000008
The full kernel log is in attachment: kernel-log.txt The device tree is in attachment: device-tree.txt The kernel defconfig is in attachment: kernel-deconfig.txt Device-tree overlay file is in attachment: dtso.txt I hope u can help me. Thanks in advance. I use buildroot 2018.05 to build the device-tree, the kernel and all the rest for a Linux Embedded device. I tried the following kernel versions: rel_socfpga-4.9.78-ltsi_18.07.01_pr and rel_socfpga-4.16_18.06.02_pr from https://github.com/altera-opensource/linux-socfpga but both have the same error.1 Reply
I think I found a workaround.
This error is caused by
Piping the content of the dtbo seems not to work anymore. The solution is to pipe the name of the dtbo file to the path argument of device-tree overlay.dtc -O dtb -o /tmp/dtbo -@ "$DTSO_FILE" cat /tmp/dtbo > /sys/kernel/config/device-tree/overlays/default/dtbodtc -O dtb -o /lib/firmware/dtbo -@ "$DTSO_FILE" echo dtbo > /sys/kernel/config/device-tree/overlays/default/path
