14 years agoK4H561638N-LCC ddr controller parameters (xml)
Anyone knows how to fill ddr controller timing parameters from the datasheet?
Specifically i need K4H561638N-LCC parameters, I think they are similar to the K4H561638F-TCC parameteres. Have I need to use the min time for the parameters? Many thanks. ifdm1 Reply
There should be different sets of timing numbers depending on the frequency. If you take the conservative "loose" approach (choose highest timing values) the interface will continue to work but it might not give you the best performance possible. You could make different configurations for different clock frequencies while you are developing in case you don't have your memory clock speed set in stone yet.
