13 years agoJTAG UART crashes NIOS if no NIOS terminal is open
Hi So, Nios was "crashing" for me. In truth, it just seemed to be dormant. As soon as I connected the Nios terminal, it magically came back to life, and some printf stuff got flushed out onto t...
13 years ago --- Quote Start --- Hi So, Nios was "crashing" for me. In truth, it just seemed to be dormant. As soon as I connected the Nios terminal, it magically came back to life, and some printf stuff got flushed out onto the Nios terminal. Anybody seen this before? I am guessing that the JTAG UART FIFO filled up. Should I really expect that Nios should simply carry on in its merry way regardless, or should it stop like this? Thanks Clive --- Quote End --- Working form memory there are different options when instantiatiating a JTAG UART which deternine if it is used for interacting with a human, or just for communicating with another device, and depending on these options there is a bit in the JTAG UART's control register that can be used by the device driver to determine if a terminal is attached. Depending on the application the software might choose to throw away some of the output characters if no terminal is attached, with the explicit purpose being to prevent a thread in the software from blocking when no terminal is attached.
