9 years agojtag programming bug
Hi all, I'm using DE0-CV board and running Nios II on this board. (I'm running a custom application on the board which is basically 7 different ''for'' loops. I can find the duration and be...
9 years agoYes, but even if everything is the same, that means the programming is the same as well. What are you using to calculate the time for your application? I presume you're using alarm functions.
