9 years agojtag programming bug
Hi all, I'm using DE0-CV board and running Nios II on this board. (I'm running a custom application on the board which is basically 7 different ''for'' loops. I can find the duration and be...
9 years agoI would not attribute this to programming. Programming is kind of binary. It either works or it doesn't. It doesn't program the board differently some times.
If possible, I'd add Signaltap to the design to see how it's running in hardware. Maybe you can capture signals when the design is not behaving the way you intend to help figure out why. Have you simulated this design in, say, ModelSim?
