14 years agoJTAG functions for writing and reading data from nios towards host pc
Hi I'd like to communicate with a nios system using a JTAG uart module, but I don't know which functions I have to use in nios C-program...I read something about printf () for sending data to syst...
14 years agoWhat do you mean by data packets? The JTAG Uart is mostly a text interface. You could probably use it to transfer binary data, but it wasn't designed for this.
If you have a network interface you can also use it to transfer data. Another way could be to run your software with a debugger and use the host filesystem software component, so that your Nios application can directly read/write files on the PC.
