16 years agoJtag error
I have been running jtag connexion since one year and this last month when I tried to download a zimage sometimes appeared this error, and I have to restart the computer if I want to continue.
$ nios2-download -g ~/Escritorio/nios2-linux/uClinux-dist/images/linux.initramfs.gz
Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 3487KB in 4.5s (774.8KB/s)
Verified OK
Starting processor at address 0xC4000000
nios2-gdb-server-wrapped: nios2debug.cpp:562: virtual ADI_ERROR NIOS2DEBUG::leave_debug_mode(): Assertion `m_state == STATE_DEBUG' failed.
/opt/altera9.1/nios2eds/bin/nios2-download: line 595: 30862 Cancelado nios2-gdb-server --go --tcpport none --write-pid /home/garcia/Escritorio/nios2-linux/uClinux-dist/images/nios2-download.pid /home/garcia/Escritorio/nios2-linux/uClinux-dist/images/linux.initramfs.gz.srec
I have DE2-70 and I use webserver edition in Ubuntu. Any ideas to solution this problem? Many thanks1 Reply
--- Quote Start --- Hi, I have been running jtag connexion since one year and this last month when I tried to download a zimage sometimes appeared this error, and I have to restart the computer if I want to continue.
I have DE2-70 and I use webserver edition in Ubuntu. Any ideas to solution this problem? Many thanks --- Quote End --- Hi I am experiencing the same problem? Can you pls tell me how to solve it? Thanks Soms$ nios2-download -g ~/Escritorio/nios2-linux/uClinux-dist/images/linux.initramfs.gz Using cable "USB-Blaster ", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 3487KB in 4.5s (774.8KB/s) Verified OK Starting processor at address 0xC4000000 nios2-gdb-server-wrapped: nios2debug.cpp:562: virtual ADI_ERROR NIOS2DEBUG::leave_debug_mode(): Assertion `m_state == STATE_DEBUG' failed. /opt/altera9.1/nios2eds/bin/nios2-download: line 595: 30862 Cancelado nios2-gdb-server --go --tcpport none --write-pid /home/garcia/Escritorio/nios2-linux/uClinux-dist/images/nios2-download.pid /home/garcia/Escritorio/nios2-linux/uClinux-dist/images/linux.initramfs.gz.srec
