16 years agoIssue using SGDMA to frame buffer
Hi, I am buffering frames using an SGDMA. I was wondering if anyone has come across the following problem: After transferring successfully to the ddr2 with several descriptors, the ready...
11 years agoHi BadOmen,
- Can I use "Full Word Accesses Only" based on my use case described in the previous post? When using "Full Word Accesses Only", is the only constraint that our read/write addresses placed inside the descriptor must be a multiple of 4? My hope is to minimize resource utilization as much as possible. - Would you recommend the use of the "Response Port" or leave it disabled? - When I'm using AV-ST to AV-MM mode, let's say I fill the descriptor FIFO with 4 write addresses. Is mSGDMA expecting the corresponding 4 sets of data available right away on the AV-ST port or does it wait until it sees data on the AV-ST for each transfer? I guess I'm wondering what happens if due to upstream error, no data shows up on the AV-ST port. - In the mSGDMA doc, a feature called "Park Read" was mentioned for frame buffering. Can you explain the concept here? Thank you!
