16 years agoIssue using SGDMA to frame buffer
Hi, I am buffering frames using an SGDMA. I was wondering if anyone has come across the following problem: After transferring successfully to the ddr2 with several descriptors, the ready...
16 years agoI could see the SGDMA having problems with small frames where the transfers outrun the descriptor. If you want a much easy way to do this check this out: http://www.nioswiki.com/exampledesigns/modular_sgdma_video_frame_buffer
I had frame buffering in mind when I designed that SGDMA so I made it dirt simple to use for video application. The example above is based on this design example: http://www.altera.com/support/examples/nios2/exm-modular-scatter-gather-dma.html
