19 years ago
isp1362 usb hcd driver
this is the philips isp1362 usb hcd driver, ported from blackfin linux 2.6.16.1 .
this is back ported patches for nios2 linux 2.6.11-uc0 .
http://forum.niosforum.com/forum/index.php...ype=post&id=142 (http://forum.niosforum.com/forum/index.php?act=attach&type=post&id=142)
The io ports fixup is for DE2 dev board, in arch/nios2nommu/kernel/usb.c .
Fix it , if your board is not DE2.
to select this driver in kernel config,
drivers --> usb --> host --> isp1362 hcd
I didn't have DE2 board to test this driver, only compile passed.
Shindou had been testing the same patches for nios2 linux 2.6.16.1 .
http://forum.niosforum.com/forum/index.php?showtopic=3552 (http://forum.niosforum.com/forum/index.php?showtopic=3552)
But I don't know if he has progress.
    --- Quote Start ---
    originally posted by goral@Apr 23 2006, 01:08 PM
    when clean all work before i do, i compile my kernel, i got so many errors, i using isp1362.diff to patch the usb driver.
    <div class='quotetop'>quote
    --- quote end ---
    --- quote start ---
    cc drivers/usb/host/isp1362-hcd.o
    drivers/usb/host/isp1362-hcd.c:1293: error: syntax error before "gfp_t"
    drivers/usb/host/isp1362-hcd.c:1294: warning: function declaration isn&#39;t a prototype
    drivers/usb/host/isp1362-hcd.c: in function `isp1362_urb_enqueue&#39;:
    drivers/usb/host/isp1362-hcd.c:1295: error: `hcd&#39; undeclared (first use in this function)
    drivers/usb/host/isp1362-hcd.c:1295: error: (each undeclared identifier is reported only once
    drivers/usb/host/isp1362-hcd.c:1295: error: for each function it appears in.)
    drivers/usb/host/isp1362-hcd.c:1296: error: `urb&#39; undeclared (first use in this function)
    drivers/usb/host/isp1362-hcd.c:1333: error: `hep&#39; undeclared (first use in this function)
    drivers/usb/host/isp1362-hcd.c:1334: error: `mem_flags&#39; undeclared (first use in this function)
    drivers/usb/host/isp1362-hcd.c:1341: warning: implicit declaration of function `hc_is_running&#39;
    drivers/usb/host/isp1362-hcd.c: in function `isp1362_mem_config&#39;:
    drivers/usb/host/isp1362-hcd.c:2415: warning: int format, long unsigned int arg (arg 5)
    drivers/usb/host/isp1362-hcd.c:2418: warning: int format, long unsigned int arg (arg 5)
    drivers/usb/host/isp1362-hcd.c: in function `isp1362_hc_start&#39;:
    drivers/usb/host/isp1362-hcd.c:2776: error: `hc_state_running&#39; undeclared (first use in this function)
    drivers/usb/host/isp1362-hcd.c: at top level:
    drivers/usb/host/isp1362-hcd.c:2818: error: unknown field `bus_suspend&#39; specified in initializer
    drivers/usb/host/isp1362-hcd.c:2819: error: unknown field `bus_resume&#39; specified in initializer
    drivers/usb/host/isp1362-hcd.c: in function `isp1362_remove&#39;:
    drivers/usb/host/isp1362-hcd.c:2828: warning: implicit declaration of function `platform_get_drvdata&#39;
    drivers/usb/host/isp1362-hcd.c:2828: warning: initialization makes pointer from integer without a cast
    drivers/usb/host/isp1362-hcd.c:2834: warning: implicit declaration of function `usb_remove_hcd&#39;
    drivers/usb/host/isp1362-hcd.c: in function `isp1362_probe&#39;:
    drivers/usb/host/isp1362-hcd.c:2927: error: too many arguments to function `usb_create_hcd&#39;
    drivers/usb/host/isp1362-hcd.c:2932: error: structure has no member named `rsrc_start&#39;
    drivers/usb/host/isp1362-hcd.c:2958: warning: implicit declaration of function `usb_add_hcd&#39;
    drivers/usb/host/isp1362-hcd.c:3043: error: variable `isp1362_driver&#39; has initializer but incomplete type
    drivers/usb/host/isp1362-hcd.c:3044: error: unknown field `probe&#39; specified in initializer
    drivers/usb/host/isp1362-hcd.c:3044: warning: excess elements in struct initializer
    drivers/usb/host/isp1362-hcd.c:3044: warning: (near initialization for `isp1362_driver&#39;)
    drivers/usb/host/isp1362-hcd.c:3045: error: unknown field `remove&#39; specified in initializer
    drivers/usb/host/isp1362-hcd.c:3045: warning: excess elements in struct initializer
    drivers/usb/host/isp1362-hcd.c:3045: warning: (near initialization for `isp1362_driver&#39;)
    drivers/usb/host/isp1362-hcd.c:3047: error: unknown field `suspend&#39; specified in initializer
    drivers/usb/host/isp1362-hcd.c:3047: warning: excess elements in struct initializer
    drivers/usb/host/isp1362-hcd.c:3047: warning: (near initialization for `isp1362_driver&#39;)
    drivers/usb/host/isp1362-hcd.c:3048: error: unknown field `resume&#39; specified in initializer
    drivers/usb/host/isp1362-hcd.c:3048: warning: excess elements in struct initializer
    drivers/usb/host/isp1362-hcd.c:3048: warning: (near initialization for `isp1362_driver&#39;)
    drivers/usb/host/isp1362-hcd.c:3049: error: unknown field `driver&#39; specified in initializer
    drivers/usb/host/isp1362-hcd.c:3049: error: extra brace group at end of initializer
    drivers/usb/host/isp1362-hcd.c:3049: error: (near initialization for `isp1362_driver&#39;)
    drivers/usb/host/isp1362-hcd.c:3052: warning: excess elements in struct initializer
    drivers/usb/host/isp1362-hcd.c:3052: warning: (near initialization for `isp1362_driver&#39;)
    drivers/usb/host/isp1362-hcd.c: in function `isp1362_init&#39;:
    drivers/usb/host/isp1362-hcd.c:3063: warning: implicit declaration of function `platform_driver_register&#39;
    drivers/usb/host/isp1362-hcd.c: in function `isp1362_cleanup&#39;:
    drivers/usb/host/isp1362-hcd.c:3070: warning: implicit declaration of function `platform_driver_unregister&#39;
    drivers/usb/host/isp1362-hcd.c:3043: error: storage size of `isp1362_driver&#39; isn&#39;t known
    drivers/usb/host/isp1362-hcd.c:1581: warning: &#39;isp1362_bus_suspend&#39; declared `static&#39; but never defined
    make[3]: *** [drivers/usb/host/isp1362-hcd.o] error 1
    make[2]: *** [drivers/usb/host] error2
    make[1]: *** [drivers/usb] error 2
    make: *** [drivers] error 2
    --- Quote End ---
    I clean my work like as hippo mentioned in this topic:
    http://forum.niosforum.com/forum/index.php?showtopic=3706 (http://forum.niosforum.com/forum/index.php?showtopic=3706)
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    # remove old linux source
    rm -rf ~/linux-2.6.x ~/mysvn/2.6.11-uc0# kernel 2.6.11-uc0 source ported by microtronix
    cp -a ~/download/mx140/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~
    cd ~/linux-2.6.x
    patch -p0 <~/download/kernel.diff
    cp ~/download/kernel.config ~/linux-2.6.x/.config
    patch -p0 <~/download/isp1362.diff[/b]
    --- Quote End ---
    Need I update my kernel or how to solve ?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14572)</div>
    [/b]
    --- Quote End ---
    These error come from the difference of data structures and APIs between 2.6.11-uc0 and 2.6.16.1 .
    Please switch back to your previous thread, and switch back to 2.6.16.1 kernel.
    jay_1025 is also working on this driver, maybe you can help each other.
    I had the same errors when compiling after applying the patch isp1362 to the Microtronix 2.6.11 kernel. I think the patch is still for 2.6.16 but I did not patch the kernel, instead I backported the sources to 2.6.11.
    Get the isp1362-hcd.c and isp1362.h file with a description how to go on after applying hippos patch.
    my webpage (http://www.8ung.at/nacide_manfred/linuxtutorial.html)
    Hi,hippo,i did everything you told about isp1362,but in menuconfig Device
    Drivers ===>
    USB support ===>
    the HID input layer support can&#39;t be chose.
    and when i build the project ther are errors in usb.c.
    can you tell me why ?
    Thank you very much.
    --- Quote Start ---
    originally posted by hua124@Oct 14 2006, 09:22 PM
    hi,hippo,i did everything you told about isp1362,but in menuconfig device
    drivers ===>
    usb support ===>
    the hid input layer support can&#39;t be chose.
    thank you very much.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18684)
    --- quote end ---
    --- Quote End ---
    You should have post this as a new topic.
    I tried the compilation, but didn&#39;t see the error. What is your error message?
    --- USB Input Devices
    [*] USB Human Interface Device (full HID) support
    with or without,
    --- Input core support is needed for USB HID input layer or HIDBP
    [*] /dev/hiddev raw HID device support
