17 years agoISP1362 - DE2-70 - kernel 2.6.30
After upgrading to 2.6.30 uClinux-dist and using ISP1362 component ISP1362_CTRL.v from http://www.nioswiki.com/@api/deki/files/131/=isp1362_ctrl.v (http://www.nioswiki.com/@api/deki/files/131/=isp1362_ctrl.v)
The only way i found for getting work full USB Host with Mass Storage Support, it was ommitting clock check at function isp1362_hc_reset
static int isp1362_hc_reset(struct usb_hcd *hcd)
int ret = 0;
struct isp1362_hcd *isp1362_hcd = hcd_to_isp1362_hcd(hcd);
unsigned long t;
unsigned long timeout = 100;
unsigned long flags;
int clkrdy = 0;
/*Se omite la revisión del reloj*/
return 1;
Now boot messages look like below with my Nokia 5310 attached to the USB-Host Hub.
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.30 (parrado@parrado-laptop) (gcc version 3.4.6)# 18 PREEMPT Sat Sep 26 12:46:58 COT 2009
uClinux/Nios II
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 16256
Kernel command line:
NR_IRQS:32
PID hash table entries: 256 (order: 8, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 62164k/2792k RAM, 0k/0k ROM (1901k kernel code, 891k data)
Calibrating delay loop... 49.35 BogoMIPS (lpj=246784)
Mount-cache hash table entries: 512
net_namespace: 264 bytes
NET: Registered protocol family 16
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
ttyJ0 at MMIO 0x8001050 (irq = 1) is a Altera JTAG UART
console enabled
Driver 'sd' needs updating - please use bus_type methods
dm9000 Ethernet Driver, V1.31
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd: irq 2, io mem 0x08001040
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968 128
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: ISP1362 Host Controller
usb usb1: Manufacturer: uClinux 2.6.30 isp1362-hcd
usb usb1: SerialNumber: isp1362-hcd
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 2
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Freeing unused kernel memory: 600k freed (0x4224000 - 0x42b9000)
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc -o noexec,nosuid,nodev
usb 1-2: new full speed USB device using isp1362-hcd and address 2
Command: mount -t sysfs sysfs /sys -o noexec,nosuid,nodevusb 1-2: New USB device found, idVendor=0421, idProduct=006a
usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-2: Product: Nokia 5310 XpressMusic
usb 1-2: Manufacturer: Nokia
usb 1-2: SerialNumber: 358990016653230
usb 1-2: configuration# 1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
Command: mount -t devpts devpts /dev/pts -o noexec,nosuid
Command: mount -t usbfs none /proc/bus/usb
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
Execution Finished, Exiting
Sash command shell (version 1.1.1)
/> scsi 0:0:0:0: Direct-Access Nokia Nokia 5310 Xpres 0000 PQ: 0 ANSI: 4
sd 0:0:0:0: Adjusting the sector count from its reported value: 3970049
sd 0:0:0:0: 3970048 512-byte hardware sectors: (2.03 GB/1.89 GiB)
sd 0:0:0:0: Write Protect is off
sd 0:0:0:0: Assuming drive cache: write through
sda:
sd 0:0:0:0: Attached SCSI removable disk
Thanks. I will update the git.
- Hippo - Altera_Forum
I don't know if it is the best post to write about this, but I do it because it is about the ISP1362 and also I work with a de2-70 fpga. I use linux with MMU and the component is the one of nioswiki, ISP1362_control.v When I boot uclinux in the initialization screen appear two lines with an error. 1-isp1362-hcd isp1362-hcd: can't setup 2-isp1362_probe: init error, -19 --- Quote Start --- isp1362_hc_reset: Clock not ready after 100ms isp1362-hcd isp1362-hcd: can't setup isp1362-hcd isp1362-hcd: USB bus 1 deregistered isp1362_probe: init error, -19 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. --- Quote End --- I think that it has relationed with the address of the component(ISR1362) and the irq, I have checked that were the same as in custom_fpga.h. I would appreciate if someone can suggest some idea about which thing I do wrong. Thanks a lot - Altera_Forum
I have look for the function that gives this error. It is usb_add_hcd in hcd.c This is the peace of code that not fulfill, but I don't know which is the source --- Quote Start --- printk(KERN_ERR "Valor menor que uno PUFF: %d\n",hcd->driver->reset(hcd)); if (hcd->driver->reset && (retval = hcd->driver->reset(hcd)) < 0) { dev_err(hcd->self.controller, "can't setup\n"); printk(KERN_ERR "Peta aki\n"); goto err_hcd_driver_setup; } --- Quote End --- Thanks for help - Altera_Forum
Sorry for my nonsense. I have the solution in front of my eyes. Sorry - Altera_Forum
hello ,parrado !
I need you give me a detailed expansion for isp1362-de2-70with uclinux-dist 2.6.30 I am porting uclinux to board for DE2_70_NIOS2_HOST_MOUSE_VGA project! thanks a lot! - Altera_Forum
hello , do you do isp1362 device controller driver for usbslave side on de2-70 board to connect a pc?
if you have done ,please give help to me! - Altera_Forum
If you post the same message several times, everybody will find you impolite and will not want to reply.
-Michael - Altera_Forum
sorry ! I will very be careful next time !!
Maybe it might be better to start a new thread instead of extending a very old one with a new question.
hello,vikonilov,can you tell how to solve your problem
