8 years agoIs sGDMA integration correct in this SoC ??
Hello all, I am using modular scatter-gather DMA core to transfer data from my custom IP: custom_design_32_0 to other custom IP: custom_design_32_1 on the stratix 10 development board. Any...
8 years agoThat screenshot is so small I cannot tell which IP in that system is the mSGDMA. In general you hook up a host like the HPS, Nios, etc... to the csr and descriptor slave ports of the dispatcher, the read/write masters to your memory, and if you are performing a streaming transfer the data source/sink to your own streaming IP.
Here is an example showing how the mSGDMA is hooked up to the HPS: https://www.altera.com/support/support-resources/design-examples/soc/fpga-to-hps-bridges-design-example.html Here is an example showing how the mSGDMA is hooked up to Nios: http://www.alterawiki.com/wiki/modular_sgdma
