16 years agoIoctl problem
I'm writing a device driver and I have problems with the ioctl function. When I run my user application associated with the driver in the terminal, "printks" that are inside my module functions appeared in a wrong order, I use "printk" to know where I am. Besides "printk" that are inside ioctl code of the module appeared without having make a call of ioctl. Maby the computer has reorganized the order of the instructions and ioctl always starts when I run a new application? I have used in my user code a file_pointer instead of a file_descriptor, althought I have used function fileno to have a file_descriptor because it is one of the paremeters of the function ioctl. I don't know how to solution these problems. Thanks Code_User_ApplicationFILE *leds;
printf("Fitxer obert Usuari\n");
descriptor_leds=fileno(leds);
fwrite(Dada,sizeof(char),1,leds);
ioctl(descriptor_leds,LEDS_IOCSETD,&Dada_ioctl);
printf("IOCTL_Usuari_Superat\n\n");Module_Code static int Leds_ioctl(struct inode *inode, struct file *file, unsigned int cmd, unsigned long arg){
static int data;
printk("\nSuper_ioctl\n");
printk("Valor_cmd:%d\n",cmd);
switch(cmd){
case LEDS_IOCSETD:
if (copy_from_user(&data,(int *)arg, sizeof(int)))
return -EFAULT;
printk("Ioct_Valor: %d\n",data);
return 0;
default:
printk("Ioctl_Cap_opcio\n");
return -ENOTTY;
}Thanks10 Replies
Do you have a doubt for the printing order of 'Super_ioctl....' and 'Fitxer obert Usuari...'? If so, please consider that the 'printf' messages are all buffered and wait the timing to send to your console. Kazu - Altera_Forum
Hi:
I suggest that add sleep(1) after printf("Fitxer obert Usuari\n"); I‘m sure module has higher priority than app。。 - Altera_Forum
Thanks for answers.
But I was referring to "printks" that are in functions of my module no "printfs". I mean in my user code I make a call of function fwrite before calling function ioctl and in the terminal I saw "printks" of ioctl before printks of fwrite and all "printks" that I have written in the module have the same priority. And also why "printks" of ioctl can appear in terminal if I don't make a call of function "ioctl", I have chosen a unique magic number. Thanks in advice - Altera_Forum
Would you please write the order of printk's message that you are expecting? Kazu - Altera_Forum
Thanks for help. Well I think that the order of "printks" should be this:
These are "printks" that I think that should appear in terminal with this order and only these "printks". I would like to understand where are mistakes. Thanks a lot.//Printk function fwrite Copy_from_user: 4 I'm here //Printk function Ioctl Super_ioctl Valor_cmd:1 Ioctl_Valor1: 5 - Altera_Forum
--- Quote Start ---
--- Quote End --- Where did you put 'printk' inside of 'fwrite'? The 'fwrite' is only a library function, not a kernel function. Kazu//Printk function fwrite Copy_from_user: 4 I'm here //Printk function Ioctl Super_ioctl Valor_cmd:1 Ioctl_Valor1: 5 - Altera_Forum
Maby I'm wrong but I'm not agree with you. It's true that 'fwrite' is a function of <stdio.h> library , but it is connected with my kernel function write. One of the parametres of fwrite is a file_pointer, this file_pointer has the same major as my driver, so when I call a fwrite in user space indirectly I call my function write in kernel. Things ara litle complex but more or less.This what I think, maby I'm wrong tell me please. Thanks - Altera_Forum
AFAIK, you can't use fwrite() (or anything from stdio.h) in Kernel code.
-Michael - Altera_Forum
We are mixing things. I know that I can't use fwrite in kernel code Michael, I 'm using it in user application as I explained in my first post. But I used this function fwrite in user application to call my function write in the kernel code. The problem is the order of printks. Thanks for the pacience Thanks - Altera_Forum
--- Quote Start --- Maby I'm wrong but I'm not agree with you. It's true that 'fwrite' is a function of <stdio.h> library , but it is connected with my kernel function write. --- Quote End --- Maybe you wrote next codes somewhere in your kernel.
And where? That is the problem. Kazuprintk("Copy_from_user:%d\n", **); printk("I'm here\n");
