17 years ago
Interruption problem with buttons
I have a problem generating interruptions. I had a design which was working with buttons on pooling. I then changed conditions in SOPC and put synchronously capture on rising edge and generate irq on edge. The number of my irq is 1. I compiled my design again and put the following program which I adapted from the program provided by Atlera (count_binary).
when I press a button, 3 leds light on which corresponds to the default case of my function handle_button_press.
Did I forget something in Quartus II for handling interruptions?
Please help !
Myriam
Program :
static void handle_button_interrupts(void* context, alt_u32 id)
/* Cast context to edge_capture's type. It is important that this be
* declared volatile to avoid unwanted compiler optimization.
volatile int* edge_capture_ptr = (volatile int*) context;
/* Store the value in the Button's edge capture register in *context. */
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE);
/* Reset the Button's edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0);
IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE); //An extra read call to clear of delay through the bridge
/* Initialize the button_pio. */
static void init_button_pio()
/* Recast the edge_capture pointer to match the alt_irq_register() function
* prototype. */
void* edge_capture_ptr = (void*) &edge_capture;
/* Enable all 4 button interrupts. */
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE, 0xf);
/* Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0x0);
/* Register the interrupt handler. */
alt_irq_register( BUTTON_PIO_IRQ, edge_capture_ptr,
handle_button_interrupts );
static void handle_button_press()
if (edge_capture!=0) printf ("Gloupix : %d",edge_capture);
switch (edge_capture)
case 0x1:
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x1);
break;
case 0x2:
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x2);
break;
case 0x4:
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x4);
break;
case 0x8:
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x8);
break;
default:
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0xE);
break;
int main(void)
init_button_pio();
while( 1 )
handle_button_press();
return 0;
