SKuma120
7 years agoInterrupt processing not working
Hello , I am new to nios programming this can be a basic question. I have two external interrupts connected to external devices with different interrupt priorities one is 1 and other is 8 . Both th...
- 7 years agoHi, Thanks for figuring out the mistake by yourself, in future I recommend you to use the VIC (Vectored Interrupt controller) IP. Regards.
Ahmed_H_Intel1
7 years agoHi,
Why you give priorities 1 and 8, is there any other interrupts between?
SKuma120
7 years agoThanks for the reply.
Yes, there are other interrupts in between. I tried changing the priorities to 1 & 2 but it did not help.
Reading the interrupt register in debug mode, i observed an issue while reading the result from one of the interface clears other existing interrupts . So the second channel interrupt get cleared and isr is not serviced.
I have to fix this now.
