20 years ago
Internal Register File (Custom Instructions)
Hello.
I'm a (very) beginner of NiosII and VHDL, and have just managed to make a
sample custom instruction (Combinatorial) like the following,
thanks to ug_nios2_custom_instruction.pdf.
unsigned char input[BUFF_SIZE], output[BUFF_SIZE];
for(i=0; input!='\0'; i++)
output = (unsigned char) ALT_CI_PROC_ONE_CHAR((int)input[i]);
Now, I'd like to extend the instruction to deal with the strings instead of chars.
I mean, something like the following is preferable.
ALT_CI_PROC_STRING(input, output);
To do this, I should use Custom Instructions(Internal Register File), right?
Could anyone tell me where I can get the examples of VHDL for this?
Or ... any other suggestions are welcome.
shino
    Not sure why you added to an old thread.
    You probably want something like:
    /* There are 'int __builtin_custom_inii(int op, int a, int b)'
     * (and similar) wrappers for custom instructions defined by gcc itself.
     * But none for the 'c' variants that do not use the main register file.
     * The one below is useful when the 'b' field is used as a sub-opcode.*/
    __attribute__((always_inline))
    static __inline__ uint32_t
    custom_inic(const uint32_t op, uint32_t a, const uint32_t b)
        uint32_t result;
        __asm__ ( "custom\t%1, %0, %2, c%3"
            : "=r" (result) : "n" (op), "r" (a), "n" (b));
        return result;
    Read the gcc documentation for __asm__ for more details.
    If your instruction saves state, then you probably need __asm__ volatile.
