8 years ago
Intel HLS not working with HLS/ac_int.h
Hello, I am trying to get a simple program working, but I can't seem to compile it with i++.
I traced the error back to this include line. If I comment it, I have a hello world program working, but otherwise, it fails to compile.
# include "HLS/ac_int.h"
Here is the full code:
#include "HLS/stdio.h"# include "HLS/ac_int.h"
int main(void)
        printf("Hello World");
        return 0;
From the errors below, I would think that I am missing some header files, but I don't know which ones or where I can find these files. I am running in CentOS 7
I am running this command:
$ i++ -v -o test -march=x86-64 main.cpp
and receiving this output:
Target FPGA part name: 10AX115U1F45I1SG
Target FPGA family name: Arria 10
Target FPGA speed grade: -2
Analyzing main.cpp
In file included from main.cpp:14:
In file included from /opt/altera/17.1/hls/include/HLS/ac_int.h:99:
In file included from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/iostream:38:
In file included from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/ostream:37:
In file included from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/ios:41:
In file included from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/bits/ios_base.h:38:
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/ext/atomicity.h:48:45: error:
use of undeclared identifier '__ATOMIC_ACQ_REL'
{ return __atomic_fetch_add(__mem, __val, __ATOMIC_ACQ_REL); }
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/ext/atomicity.h:52:38: error:
{ __atomic_fetch_add(__mem, __val, __ATOMIC_ACQ_REL); }
In file included from /opt/altera/17.1/hls/include/HLS/ac_int.h:108:
In file included from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/algorithm:61:
In file included from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/bits/stl_algo.h:59:
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/cstdlib:165:26: error:
use of undeclared identifier '__builtin_labs'
abs(long __i) { return __builtin_labs(__i); }
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../include/c++/4.8.5/cstdlib:173:31: error:
use of undeclared identifier '__builtin_llabs'
abs(long long __x) { return __builtin_llabs (__x); }
4 errors generated.
HLS x86-64 compile FAILED.
Any help would be appreciated.
1 Reply
    HLS Compiler not is supported on CentOS 7 may because of this you may get this error.
    The code works fine on windows 10.
    http://dl.altera.com/requirements/17.1/
    Anand Raj Shankar
