8 years agoIntel HLS example reports
Hello, I am new to the concept of HLS. I am using Intel HLS and going to start with the examples that come with the installation of Quartus prime edition. Can anyone of you share the succe...
8 years agoDear Anand,
thanks for the reply. The other HLS tool is Vivado HLS and it is showing no error and test bench runs fine in that tool. I converted the code in Intel HLS format while using ac data types. My request to you is if you have a intel HLS compiler in your machine, can you run the above code and check if test bench passes or not.... I will be really grateful.
