8 years agoIntel HLS example reports
Hello, I am new to the concept of HLS. I am using Intel HLS and going to start with the examples that come with the installation of Quartus prime edition. Can anyone of you share the succe...
8 years agoDear Anand
thanks for the reply..... I am trying to compile a very simple C++ algorithm. The din_t I am taking as ac_int<16> and d_out I am taking as ap_int<48>....The length of vector as N=10... I have compiled it in another HLS tool.... I will be grateful if you can check if I am following the right difrection towards synthesis in Intel HLS..... In my code there is a component and below i have the test bench under int main(void)....This test bench works in other HLS tool.... I am having problem in Intel HLS with this...Can you figure out what is wrong in it ? Will be really thankful... # include "HLS/hls.h" # include <stdio.h> # include "HLS/ac_int.h" # include "HLS/ac_fixed.h" # include "HLS/math.h" using namespace ihc; component void sol (din_t a[N], din_t b[N], dout_t *dout) { int i; int acc= 0; int a_reg, b_reg, sub, sub2; for(i=0; i<N; i++) { # pragma HLS PIPELINE II=1 a_reg = a;b_reg = b; sub = a_reg - b_reg; sub2 = sub*sub; acc += sub2; } *dout = acc; } int main(void) { int i, k, cnt; int ret_val = 0; int a[N], b[N]; din_t aa[N], bb[N]; long long int ref_res; dout_t res; cnt = 0; for (k=0; k<10; k++) { //create random data for(i=0; i<N; i++) { a = rand() % (1024*16);
b = rand() % (1024*16); aa = (din_t) a; bb = (din_t) b; } //call reference function ref_sol(a, b, &ref_res); //call design Under Test sol( aa, bb, &res); //check results printf("got %lld expected %lld\n", (long long int) res.to_double(), (long long int) ref_res); if ( (ref_res - (long long int) res) !=0 ) cnt++; } if (cnt>0) { printf("TEST FAILED: %d errors\n", cnt); ret_val = 1; } else { printf("TEST SUCCESS!\n"); ret_val = 0; } return ret_val; }
