8 years agoIntel HLS can not generate execution file
Hello,I am trying to use Intel HLS ,but it seems has some problem. I have used windows7 and Quartus 17.1 pro. This is my code: # include "HLS/stdio.h"
int main() {
printf("Hello ...
8 years agoHi,
To check if VS2010 installed properly. Can you run the example in Quartus 17.1 using a build.bat file and check? https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/hls/ug-hls-getting-started.pdf http://www.alteraforum.com/forum/showthread.php?t=58215 Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
