17 years agoIncorrectly reading system timestamp?
I have just tried to migrate my design into Quartus II 9.0SP2 (from 6.0). After overcoming several other hurdles, I seem stuck on this one. My design has compiled just fine, but when I try to Debug...
17 years agoActually, I am not using the Flash Programmer. This problem occurs before reaching that stage anyway - i.e. when I'm trying to Debug in Nios. The Flash Programmer is limited to a single processor, so I use the text commands in the Command Shell to program, but I need to debug the program first.
Is there a way to set a similar option for Debugging? Even so, I'm not happy with this as a permanent solution, as the verification is normally a good thing to keep it idiot-proof and make sure I don't download the wrong .sof file.
