8 years agoIncorrect read data from sdram in NIOS using IORD_16Direct
Hello, i have a problem with reading data from sdram in nios using IORD_16direct. There is my code of sending data to sdram. for(i = 0; i < 10; i++) { int chromosome[30] = { 0, 1, 2, 3, 4...
8 years agoHi Nurbek,
Debug the code using following steps. 1.Print the write and read address and verify. 2.Or instead of for loop can try something much simpler(write to two address and read from the two without loop) if u succeed try with loop. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
